suprarx7nut said:
Ya, I'm planning on new brakes all around, possibly the 935 motorsports slotted rotors with some good pads. As far as the cooling system goes is there a good way to test the various components?
Thermastat is brand new from toyota, as well as cap and fluid. Its never overheated or even gone above halfway. Radiator is some aftermarket brand previous owner put in...
Are there any sort of test I could do to determine the strength/effectiveness of the system?
Change all your fluids, trans, coolant, rear end, and bleed all your old brake fluid out and use, like Poodles said, the best fluid you can find, DOT 4.
It's also a good idea to take it to a mechanic that can put it up on a rack and check everything out. Sometimes somebody else can spot something that you might miss and it usally doesn't cost much($25-$30)
DO NOT the first couple of times go with racing tires. Just use a good street tire like everybody has suggested. You'll get to know the squeel, then squalk of a street tire's threshold. Like MKIII said racing tires are sticky, but when they let loose you really have to be quick and know the limits of your car. As far as the brakes, yeah if you can upgrade rotors and a good pad. Our if you have to, use stock rotors with a good pad, just ease into things, in slow-out fast. Make sure you take extra brake fluid when you go, and check your brake fluid after you run for a while. It will usally drop some depending on how fast the track is. I've seen guys have to put on an extra set of pads during the day, just make sure you bed them before you need to stop quick. Extra quart of oil in the pan helps too and one or two on hand.
There are things you can do to check out the cooling system, just search and read the TSRM.
Running on the track is a lot of fun and it is hard on your car, but if you maintain it well enough and don't overdrive your limits or the car's, you'll be hooked.:icon_bigg
