I decided to get my vacuum for my EVC off the hard line that goes in front of the engine for the p/s idle up.
Now I have read in the instructions:
Would where I have the evc vacuum connected have anything to do with that?
If not, check my mods in the sig and see if you can see why I may be running so rich. FYI I don't have the RebicLC turned on.
I do have a new O2 sensor to be installed.
Well, that line does also control the vacuum for the fpr vsv. I seem to run rich at wot - 9.6a/f and black smoke when accelerating.· Do not connect port #1 to the line that operates the fuel pressure regulator unless the supplemental instructions tell you to do so.
