retorqing head studs?
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ. said:
It's not rocket science guys! ;)
The ARP's come with instructions and Moly Lube just follow em and you'll be fine.
Personally I'll do the ReTorque everytime but rule of the thumb is
New HardWare = ReTorque
Heat Cycled HardWare = Personal preference.
Mechanical engineering = Yes . Rocket Science = No
I'd like to know where all the different "spec" torque numbers come from you hear thrown around. I still can't find an ARP spec sheet for the bolts...
malloynx
NC
I don't care what people say. I have ARP studs and after they are heat cycled the will come loose. i didn't do a retorque and at 23psi i was losing some coolant. when i went to remove the head the middle 4 studs were loose
jdub
Feb 10, 2006
10,730
Valley of the Sun
I've been wanting to see this...it explains where the 75 ft/lbs torque value comes from. This is a spec sheet for the ARP Head Bolts...thank you.
FYI...the thread subject concerns ARP Head Studs
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Yeah, okay you win! :biglaugh:
.... But basic physics still applies. Both the bolts and the studs are made from the same material (190,000 psi). Okay, so what's the difference between them. For studs, the nut rotates on the fixed bolt, and the thread friction is both less and stays more even as the nut is tightened. For the bolts, the thread friction increases both because we have a non-ideal thread interface of cast iron and bolt steel, and also because the thread contact length monotonically increases and the bolt descends into the block. As a result, the spec for the bolt to achieve 75% rated strength is 4ft-lbs higher (85 versus 81) and the actual statistical error in achieving the target 75% value is greater because the thread friction uniformity from bolt to bolt is lower than for the studs.
So, conclusion #1 (as you can verify elsewhere on the the net if you don't believe me) is that studs achieve target of 75% of yield strength with lower applied torque and will be statistically more uniform across a given number of them. This is why studs are preferred.
Okay, so what about aluminum. It is common knowledge that the strength of aluminum is lower than steel (Youngs modulus 69 GPa versus 196 GPa for iron), and the thermal expansion coefficient is higher (23e-6 versus 12e-6 /degC).
That means, that aluminum expands twice the amount of iron, and is 3x weaker too. What does the metalurgical engineer do? He backs off the initial cold preload on the bolt because he knows that when hot the expanded aluminum will tighten up the bolt more than for iron, and if he is too tight initially it will hit 100% yield and stretch.
Here's aquote from ARP
"Heat, primarily in aluminum, is another problem area. Because the thermal expansion rate of aluminum is far greater than that of steel it is possible to stretch a fastener beyond yield as the aluminum expands under heat."
Conclusion #2. Aluminum expands more than iron and needs a lower cold preload to prevent exceedin 100% yield when hot.
Note that conclusion #2 is exactly why ARP derates the recommended preload 12% from 85 to 75 ft-lbs for aluminum applications. This derating also applies to the studs, since the physics is the same. For studs, the instructions don't mention anything about aluminum applications, and in my opinion based on the physics that I was taught (at Caltech by the way) that is an error. I would personally derate the torque spec for studs from 81 to 71 ft-lbs for aluminum if I was using them.
Okay, the ARP specs basically assume that we are bolting together two monolithic slabs of metal together. The above specs from ARP consider only the yield strength of the bolts, and nothing else. That of course is far from the case. The head in particular, is full of cavities and holes, is made of soft aluminum, and is easily warped.
I ran a very simple finite element stress analysis (ANSYS Mechanical) of the 7M. It made some gross simplifications to both the block and the head, and uses nominal values for the iron and aluminum since I have no data on the true metalurgical grade that Toyota uses. These results must be taken with a grain of salt, but I saw a very nonuniform gasket loading that got worse as the bolt torque increased. Up to 100 kpsi it looks okay, but strange things happen as the load increases eventually getting very scary as the head/bolt interface pressure actually starts to decrease midway between the bolts as the head get distorted by the bolt pressure. This results seems a little weird to me, so like I said take this model with a grain of salt
My analysis is obviously off, because people are running at ridiculous torques according to the posts here, in some cases even beyond the yield strength of the bolts. Nevertheless, for an engineer like me, I'm not about to use the ARP spec based solely on the yield strength of the bolts. Based on my look at the 7M, I don't recommend the high torques you and others are advocating.
PS
By the way, the auto industry as a whole is moving towards metal MLS head gaskets. One of the big reasons is that a MLS requires *less* preload than a composite. This means the manufacturer can go to a *weaker* and lighter design for the head and block because they get to decrease their bolt torques without compromising performance thereby saving weight, reducing costs and increasing their CAFE !
jdub
Feb 10, 2006
10,730
Valley of the Sun
Nah...this is not about winning. Nice write-up BTW.
I don't disagree with what you said, but the majority of the folks on this forum are not engineers (there are quite a few here tho ;) ). All we have is the spec sheets...I've never said you should torque above spec on the ARP hardware. In fact, that can be a very bad thing as you approach 100% of rated strength...you're begging for a failure as you and other guys here have pointed out. That's actually why I was looking for the ARP bolt spec...I saved it for future use when I see all kinds of numbers flying around :naughty:
All I want to get out to is to follow the spec and not use the "well, my buddy told me" method of engine building. Also, it is very important to use the correct lube for the torque specified...you use 105 ft/lbs with moly on the studs, you just went to 100% of the rated strength...not good!
Hope you hang around...we can use good engineers here :icon_bigg
MKIIITrbo89
West Chester PA
Well said IJ, makes perfect sense.
My mechanic just works on imports and I stopped to talk to him yesterday. I asked him about retorquing my ARP studs that were used with the cometic MHG. He said retorquing was not necessary. Maybe he is old fashioned or doesnt realize it I don't know. Anyway I'll probably do the retorque myself this weekend.
**Also could someone please explain the benefit loosening the studs before you retorque them. If I would not have read that I would just retorque them and make sure they are at the right specs without looseing them first. I assume it won't but it just kinda worried me that you would break the original seal. Also I assume it does not matter the pattern you loosen them in as long as you follow the Toyota TSRM specs when retorquing?
And with the consensus of this thread I should be safe torquing to 81 even though 3p kinda disproved that?
jdub
Feb 10, 2006
10,730
Valley of the Sun
You don't loosen the nut/stud, you "crack" it to where it just barely moves. You do this to get an accurate torque reading when you re-tighten. As for me, I'm gonna use the ARP spec sheet for the torque settings...make sure you use the orginial setting for the lube used (moly or oil)
jdub
Feb 10, 2006
10,730
Valley of the Sun
sleepersupra said:
i just checked mine last night and the torque was almost perfect. are they suppose to loosen up? or is this a "just in case thing?"
That's good! It's just a very good thing to check...if they do loosen up for whatever reason, then a BHG is the next thing to follow.
