replacing rear trailing arms
malloynx
NC
well i got me a sweet set of the new SUPRASPORT Alumium trailing arms. any tips for removing the old ones? how do i get that bushing out of the rear knuckle?
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Check the TRSM. There is a SST they say to use, and maybe even remove the hub assembly.
But of course it can be done on the car with a "Ball Joint" tools set from Mac, Snapon, or Matco, or independent tool truck guy. I did it on the car with one of those sets I borrowed from someone.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
umm poping out the old bushin till eb chore iw ill telly uo that much
best way is pentrating sovlen and vise and big sock the size of the outer race and hammer and start pounding tell she comes out just don't favor one side fo teh race or it will jam
have fun oh yae engery spetion doe smake bushing for our arm you have to mods it take as in cut ti down but ti will fit i digg though my recipe to see fi i cna get part number for you
figgie
Twin Cities, Minnesot-ah
TurboSupra7 said:
...lol...what?
don't mind Nash
he is the exception to Mike's post.
He is our resident Dyslexic ;)
<-- takes out the Naskmanthedrunkmaster translator
nashman said:
umm popping out the old busching will be a chore that much I can tell you.
Best way is to use penetrating solvent and a vise or a big socket (the size of the outer race) and hammer and start pounding until she comes out, just don't do only one side of the race otherwise it will jam.
Have fun, and oh yeah, Energy Suspension does make some bushings for our arms, except you have to mod it, as in cut it down to size, but it will fit. I will dig through my reciepts to see if I can get a part number for you.
:bigthumb: to the nashman translator!! ;)
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
When did they come out with Aluminum ones!!?? Do they look the same as the cast pieces? Are they as strong? What else have you been keeping from me!
eric
malloynx
NC
THERE IN!!! very simple installed and now i have 0 wheel hop. They came in at 4lbs on the scale. super light and hella strong
also minecamewith poly bushings already installed. another great product from SUPRASPORT.
WILL HAVE PICS LATER
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I was gonna say, whatever you do don't break a wrench and crush your middle finger on the pinch weld. It hurts. Also, don't kick a stray jackstand across the garage. You'll probably lose a toenail also. :bigthumb:
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i love the word hella
and fyi for everyone else its a bolt in affair... just be sure to have a breaker bar or you'll be bending a lot of (hopefully lifetime warranty) tools taking the old ones out
Stretch
Toronto, Ontario
Ok, so are these aluminum bars just as good as the stainless ones? Iask because the steel ones weight 6lbs more, but if they are structurally stronger I would buy them. If you say the aluminum can take the heat just as well then I would buy them for the weight saving. Both sets are the same price anyway, I just want to know.
eric
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well here is tid bit for you cast auimn is stiffer then stainless steel
if i remmber right and pretty sure i am right
stiff ness is what you want as for t breaking in half i cna see that haven there i bone type of arm
Nope even a low grade of Stainless is 90000 psi compared to the best Aluminium at 83000 psi.
malloynx
NC
i was told by greg at SS that the alumium ones are just as strong as the steel ones. these things are hardcore. i will post pics today. i need to get batteries for my camera
