Its that time of year again where I have really random bad luck with the car. At least this year I don't have to replace the chassis, first time in 3 years :naughty:.
No, this year its the rear timing cover gasket. Decided to slowly leak coolant (originally thought to be water pump gasket), now stream out after i pulled a chunk of gasket out right around the pump near the one water pipe that runs around the engine block. Few things:
1. Tips? Suggestions on other things to look over as the engine is coming out. I'd like to make a list and order ALL parts I need ahead of time so I have no surprises (though we all know its inevitable)
2. I have my worries about head removal. I'm using HKS Stopper, now about 20-25K since its rebuild. Is it possible to remove this cover w/o removing the head? Or is this ill-advised? I would definitely prefer not to remove the head as I don't want to risk it not sealing again.
3. If the head must be removed, what are the steps to reuse the HKS Stopper if that is possible. Also, are the ARP head studs ok to be used again?
4. I've noticed randomly and rarely that car will throw some white smoke at idle (only hot, noticed when at stop lights). It doesn't happen very often and goes away once i hit the throttle and/or burn it out. I noticed when i caused the leak to get worse, the smoke got much worse and consistent. Is this coincidence or is somehow coolant getting into the chambers from this leak?
-Thanks in advance
-Thanks in advance
