Replacing HG On My 88
Stock bolts: stock torque 58ftlbs WRONG torque to 75.
Arp: They come with lube and a torque sheet. Torque to what the sheet says with the right lube. If using arp use the arp lube. Its awesome lube.
Torqueing: Always use 3 passes. Ex: stock bolts to 75. Torque 25 then 50 then 75 final. I always click the torque wrench 2-3 times to double check and go over all after.
Always use the torquing sequence in the tsrm
Do not ghet that confused with the removing sequence.
