You need a new copper crush washer for the oil feed, gasket for between the turbo hard lines and the turbo, and the gasket between the block and the oil return. I usually just use copper, high temp FIPG for these 2 gaskets and I haven't had a problem yet.
EDIT: this is if you are just replacing the CT with another CT. If you are changing to another turbo there is more.
