I have the RPS 3200# Pressure plate with a sprung six puck disk on my car and it seams to be too much for the stock clutch master cylinders. I have gone through 1 used one from a parts car, 1 I rebuilt with toyota parts, and three discount auto replacements 1 cheap and 1 high end. I replaced the high end one under warranty a couple of months ago, but it is starting to fail again.
The first sign of failure is when the pedal coupling starts to wallow out and get loose. It is apparently a rubber link with the cylinder actuating rod and after a few months it gets loose and fails to apply all the pedal effort to the cylinder actuating rod. You can feel it getting loose in the pedal action along with an occaisional groaning when depressing the pedal. The next symptom is a steady decrease in the height of the point of engagement from the floor.
The clutch engagement has been about half way up from the floor since I first put the clutch in. The pedal adjustment is about as far out as I dare go with it. This coupled with the fidanza flywheel and very grabby clutch makes it kinda hard to enjoy driving in stop and start traffic. I like it fine when it has a brand new master cylinder, although a more normal point of engagement would be nice.
Is there some kind of upgrade to this whole pedal/cyl system which will dispense with this aggravation? Any one else have/solve this problem?
