removing tems
89supra884
170
chicago
well i have my 87 5 speed turbo, and i want to remove the tems with all the wires. does anyone have any good procedures on how to do that.
thankyou
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
there is no real reason to do this unless you are replacing the suspension with non-compatible shocks. just unbolt and remove. Very self explanatory.
mk3tattoos
1,104
Bremerton, Wa
so your saying there is no need for a spring compressor to remove them?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Ha I would like to see someone rip the whole TEMS circuitry out of the car. that means it will take you 7 weeks to take each wire out of a harness, take the dash out to, take everything out. Good luck with that!
jimi87-t
1,127
5
Colorado Springs
Just unplug the actuators, remove actuators, and hide/tuck the wires away.
The only way to fully remove the system is to replace the shocks or go with coilovers, and trace wires back throughout the car and remove.
Big waste of time to trace all the wires back. IIRC you will have to pull off the fenders and pull out a lot of the interior to get to the wiring,
just hide the wires.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Pointless to remove the wiring unless you're building a race car.. My non-TEMS car has the wires and plugs for it in the engine bay next to each shock tower.
rayall01
901
Westfield, ma
Let me clear this up. If you're just removing the tems actuators, you will NOT need a spring compressor. If however, you are replacing the struts, you WILL need a spring compressor.:aigo:
89supra884
170
chicago
i want to remove the tems out of the 87 5 speed turbo, and put it over to my 89 na auto. i am soon going to do a whole engine/trans swap. so the wires for tems are in my 89 right now ???
rayall01
901
Westfield, ma
I believe the wiring harness for for all supra's have the tems connectors, as it's less expensive to make one universal setup as opposed to multiple setups. You will have to move the computer over though. I could be wrong though, like I said that's just my belief.
figgie
Twin Cities, Minnesot-ah
4 hours actually.
Not that difficult to do. Hardest part is unwrapping the said harness from the tape/tubing that toyota uses.
