Removing PS...Need a Dry Rack?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
SupraOfDoom;1488197 said:
Loop or keep it. Don't run it dry. Or if you know anyone with a 5.0 Manual rack... rumor has it that it works ( Really not much information on it ). Duane says he prefers looped to having PS...
Rumor is almost right. It can be *made* to work, sure. However, it's certainly not a bolt in solution.
Dec 3, 2003
6,653
Canada
Poodles;1488207 said:
No way in hell I'd drive at the limit in my car without PS. Bump steer FTL...
Funny you say this. I had a pro driver drive my car at the track and he said it was a better without as he could feel the car better.
You guys didn't drink enough milk if you think no ps is hard. lol
Duane
Duane
A track is very smooth. Also of mention is that at higher speeds the PPS is all but shutting the power steering off.
Dec 3, 2003
6,653
Canada
A track is smooth, but isn't straight. I am speaking specifically The Streets Of Willow, awesome track!
Sure the PPS is good, no great, I'm speaking in general if people that have it off, it isn't as bad as some portray.
Duane
Yeah, I've hit some back roads pretty hard and hitting a bump mid turn you'll need the assist to keep it on track. The miata will hit you hard with a bump in a corner but as the car is so light and the way the chassis is setup it's not hard to control if it does go a bit screwy.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
This is all theoretical however.
Everyone knows that supra owners never speed or drive "out of control" unless we are on a closed track. It would be illegal otherwise.
In all seriousness, I never pushed my car very hard without the power steering, but I would be worried about more than a bump if I were to be going 1.5 or 2x the speed limit.
Kota
105
michigan
GrimJack;1488190 said:
This depends a lot on what kind and size of tires you are running on the front. Skinny tires that are built for mileage rather than grip? No problem. Wide sticky rubber? Better work out more, son.
i have wide fronts, but i dont have a problem steering
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
GrimJack;1488417 said:
Can you parallel park on dry pavement using one finger? I can.
People still do that outside of major cities?
I do not NEED to do it, therefore I do not know if I can :p I can back it in with one hand however.
