Im installing a set of steering spacers on my rack and pinion.  Have the car up in the air on my lift.  Already installed the driver side but the passenger side is being a pain.  Seems like on the inner tie rod there is a bracket that holds onto the steering damper.  I turn the tie rod to loosen it and the bracket hits the subframe.  Im thinking I might have to loosen up the rack mount on the passenger side and see if i can't slightly move the rack front to clear the subframe but I was wondering if anyone knew an easier way. :1zhelp:
