adampecush, I checked the wiring from the ignitor to coil 1 and that appears to be good (I'm getting continuity at least). No, I can't get it to idle at all. If I keep the phasing settings that FC indicated, it feels as if the engine is trying to start as it sounds like I'm getting some type of ignition. If I change the phasing to what you have, I get nothing. I'm a novice at this and I'm wondering if my settings are incorrect. Here's what I have (I'm wired for sequential injection):
SEQUENTIAL IGNITION
Ignition Phasing:
Ignition sync: 24 teeth
Pickup Delay Comp: 130.00
IGN Tooth #1: 0.5
IGN Tooth #2: 4.5
IGN Tooth #3: 8.5
IGN Tooth #4: 0.00
IGN Tooth #5: 0.00
IGN Tooth #6: 0.00
IGN Tooth #7: 0.00
IGN Tooth #8: 0.00
IGN Tooth #9: 0.00
IGN Tooth #10: 0.00
- turn off multiplex (uncheck the box that says "Ign Mux Ign#1")
- Cam/Crank Sensor Options: Spark teeth = 12
- Enable Coils 1,2,3 and knock 1 & 2 for each
- Set the Coil Dwell Wizard for Toyota Coil (93-98 3.0L Non Turbo)
SEQUENTIAL FUEL INJECTION
- Disable injectors 4,5 and 6. Activate injectors 1,2,3 and 7,8,9,10. Also set "O2 feedback 1", "primary", and the appropriate knock sensor.
- Change cam crank sensor fuel teeth to 24.
Injector Phasing:
Inject Tooth #01=0
Inject Tooth #02=16
Inject Tooth #03=8
Inject Tooth #04=0.00
Inject Tooth #05=0.00
Inject Tooth #06=0.00
Inject Tooth #07=20
Inject Tooth #08=4
Inject Tooth #09=12
Inject Tooth #10=0.00
