IJ.;1772530 said:Is that how you did the beeper in the short bus? :nono:
yes. ? And if anyone else needs help with their...short bus... modifications I'm your man.
mkiiichip;1772460 said:Its that thing under the dash, making the beeping noise. Its under the dash, beeping.
Supracentral;1773131 said:
iwannadie;1772469 said:You are running the radio off the battery but are worried that a few gauge lights will kill your battery... ?
Dan_Gyoba;1772471 said:Turning the ignition to "on" will run the fan (if on) and power the ECU and dash lights. In comparison to the radio, the only significant drain in that is the fan, which you can simply switch off.
