is it possible to remove the oil pan and replace the gasket without removing the engine or front axle?
pretty much thats what i thought thanks guys.suprarx7nut;1199735 said:Unfortunately, either the subframe or the engine need to be disconnected or removed.
Time for a rebuild?
but without taking the oilpan out,but just taking all the screws and lowering it just enuff to replace the old gasket with new one.would that be possible do to a slow oil leek?supraman508;1200107 said:pretty much thats what i thought thanks guys.
but is it still possible to do that without removing the pan,but lowering it a couple inches and still clean the mating?Clip;1200136 said:you've gotta clean the mating surfaces well
Thats what i wanted to see.thanks i'll try that next summer.AJ'S 88NA;1200183 said:Yes it is possible, I've done it with an extra 2" drop on my oil pan. It was a PITA but can be done.
