Relocated Climate control.. now clock deasnt work and heater doesnt blow :(
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
as the title says.. i relocated my climate conrtol to my center glove box and now my clock doesnt work and my climate control works (everything lights up, temp. changes, you can hear things working when you switch where it vents.) but the problem is that the fan doesnt blow anymore.. and before this everything was fine.. where do i start?? i looked over the wiring and it looks good. i spent hours... idk where or wat to check now..
btw i checked the fuses at driver kick panel and they are all good.
how would re-wiring my cc effect my clock?? lol
Kevin
Apr 20, 2009
865
Cut and soldered. But I think I mixed some wires up because I did one harness at a time and I thought that all the wires were different but found maybe two sets of wires that were pretty much exactly the same. Lol wen I change the fan speeds nothing but clicking noise and when I change the tempurature it changes the blower speed lol
but I'm confused about why the clock no longer works lol tomorrow morning I'll switch the wires around and see what happens
Kevin
Apr 20, 2009
865
Ok so I fixed the clmate control. Turns out that I mixed two wires up. It was two blue with yellow stripe wires on the larger harness .
But after fixing that, my clock still doesn't work?? I dont understand what caused it because the only thing I did was the climate control ... So what causes it to stop working? And which fuse it it connected to?
Kevin
Apr 20, 2009
865
dome light only turns on when my door is open (middle switch).. but individual buttons dont work with door closed or opened :S
tails work.. but i occassionally get the tail light failure light on the dash when it rains?? lol (leaking hatch i guess)
