Release Bearing Assembly Fit. Loose or Tight
improved
Running!
Apr 4, 2005
195
California
Hello Forum,
I'm installing my clutch and I was mocking up the pressure plate alone with the release bearing assembly assembled. When I picked up the pressure plate, I noticed play in the Bearing Assembly, mind you I'm using all new Toyota rings, washers, and bearings on the assembly.
Is the play supposed to be there. As a unit itself it's tight, but when attached to the pressure plate there is movement. Meaning I can move the pressure plate around with the hub in the center, C-clipped in.
I installed 6 pieces of the hub together, which was shown on the TSRM and EPC from Toyota. So I'm not missing any washers or clips. Maybe paranoia...
Cheers,
Matt-
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
You shold have hardly any "in and out" movement, but can move it "around" on the diaphragm. It all centers up when fully assembled.
Mine wasn't loose at all, I could move it around, but it took some effort...
That was with every part being BRAND NEW from the dealer. When I took the clutch out to change it it had loosened up some, but it still has zero in-out movement (this is why the wave/cone washers are so critical, and why having it put together properly is critical)
improved
Running!
Apr 4, 2005
195
California
All the parts I used are new from Toyota and the Acton clutch set is new as well. There is no in and out play.
However I did notice different pressure plates, depending on its manufacture, have a layer of paint on the mating surface for the throwout bearing. Perhaps this coat plays a role in the hubs fitment. Perhaps this is why, when you removed the hub again it had the play I currently have. Perhaps, I installed it incorrectly.
When disassembiling the hub I was careful to note the order and direction of the washers and clips.
I have the orignal hub. When I get time I'll take photos of all the pieces and we(forum) can, for future reference, have an illustrated guide to the hub. It would help for some people...Right?
Cheers
Matt-
