Relay question
Status
Not open for further replies.
89turbosupra
163
oxnard
I was wondering if anybody has some pictures of tha pass. side by the intake. I see two loose connectors and am wondering what they are for? Does it control the A/C? Im trying to get it working but i dont have power to the clutch so Ill keep looking.
89turbosupra
163
oxnard
do you happen to have a picture? Is it just an end terminal that a relay plugs into, or does it have some more wires coming out from it the previous owner might have ripped out?
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
The sensors each look like a 2-wire coolant sensor, screwed into the high side a/c metal line, running along the frame.
If you are not using a/c, then they won't matter.
89turbosupra
163
oxnard
I know what sensors your talking about but thats not what I wass looking for. The connectors Im talking about have a 5 blade female plug that looks like a relay goes to them. I believe one is the clutch relay that goes to the high pressure switch you were talking about.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Are you talking about the #2 and #3 fan relays?
You'll have to pull out the wiring diagram to see if the AC clutch is affected by either of these.
89turbosupra
163
oxnard
I pulled a daigram from all data and it said its an a/c magnetic clutch relay located on the pass side. I jumped them both and one fan turned on so I figured the other was for the clutch.
Status
