relay for retractable mirror setup
macjac69
274
Mississippi
I'm thinking about getting a retractable mirror setup but I want to know if the relay that comes with it will fit in a USDM car and if it does where does it connect to in the car.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
I'm not sure about the answer to this question but I saw what you wrote and thought I was suggest the following. Some guys wire the mirrors to the accessory on the ignition and when you go to turn the car on, when it clicks to acc. they will fold out. Then fold in when you turn off the car, just a suggestion.
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
relay box normally sits in left door connected to door harness
most people selling mirrors sell the relay to go with it... i have a set here complete but i'm awaiting on a previous buyer to get home and finally unpackage them and make sure they arrived safely heh
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
genius! I never got those because of the fact the switch doesnt fit LHD cars (sc300), but with that idea, that i like alot better then a button, i'll just have to do this :)
One downside.. USDM SC300 have heated side mirrors, the JDM have ultrasonic which doesnt work as good.
macjac69
274
Mississippi
I'm kinda dumb when it comes to mechanics! So where is the plug on the door harness? Is there a unused plug on the harness in the door or do you have to hardwire?
suprra_girl
7M POWAH! ;)
www.supra.co.nz
if you were sitting in the car.... left side, it would be in the bottom corner closest to the door hinges... i believe you guys have a mirror control box there, it's just not retractable one and the plug is different so yes you'd need to rewire etc
(i'm not sure if toyota reversed the location of the box in lhd tho so it could be in the right side door)
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i had to put the control box in the right door.the switch just replace's the one you have now in your console
