Redline Shockproof Gear Oil?
dejacky
175
"taxus"
Has anyone found it easier to shift their R154 transmissions with the Redline ShockProof LIGHT oil instead of the HEAVY version?
This is not a 7M-GTE Tech question...thread moved.
If you read the Red Line spec sheet on this oil, you will find it's designed for heavy loading like you would see on a drag car. Not much point in using it IMO when MT-90 will do a better job for the street.
dejacky
175
"taxus"
I don't think MT90 is the best transmission oil for the R154 when it comes to wear AND shift quality. I'll try the Redline Shockproof light and report my findings in the blog.
Tajabaho1
117
Socal
if you use MT-90
beware, sometimes it wouldn't go into 2nd or 4th gear, although that problem seems to dissipate it's self
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Every one recomends nothing but Redline MT-90
Using a little shock proof may help but you dont want to use pure shock proof because the R154 syncros dont like it from what I have been told.
Keep telling yourself that :rolleyes: MT-90 was made specificly for transmissions that call for GL-4.
Tajabaho1;1430425 said:
if you use MT-90
That's your transmission, NOT the oil.
mkIIIman089
Ohio
I think you should try it, the risk, aside from cost, is next to nothing and you may find something you like.
I went from the Redline oils to Mobil 1 syn 75-90 (yes, the one with the LSD additive in it) on a long shot and to my surprise it has definitely improved shift quality in my worn out R154 over Redline. Despite the fact that everyone on here will say you're a fool for running anything other than MT-90...
Try shifting fast ;)
It may feel "smoother" with an LSD additive, but it's not functioning as intended and will slow your shifting down and wear worse.
mkIIIman089
Ohio
dejacky - Like I mentioned before I think you should definitely try it for yourself. You'll always have forum goons, like Poodle here, telling you why everything will wear faster, shift worse, burn your car to the ground and kill 10,000 puppies if you don't [insert what every other lemming says here]...
mkIIIman089
Ohio
Over the past 4-5 years I've tried:
Redline MT-90
Redline 75w-90NS
Redline 75w-90 (regular)
Amsoil Severe Gear 75w-90 (really didn't like that stuff)
Mobil 1 75w-90 syn
So yes, I can.
dejacky
175
"taxus"
I appreciate everyone's input. Something I've noticed about the redline shockproof heavy oil is it being more difficult to shift when the car is warmed up or has been driven for a while. I can only relate this to the higher hot viscosity number of the oil. Shockproof light has a lower cold and hot temperature viscosity, so I'm hoping this will help my Soarer R154 shift more effortlessly. The cold temp viscosity of shockproof light is 80, whereas MT90 is 90, so it will be interesting to feel any difference.
I've used MT90 in a w58 transmission and it was good, but not sure if it was "the best." Has anyone tried Castrol VMX80 as well?
