mk3ukr;1394252 said:It is on the bottom of the left column
"The most significant improvement comes with the ability to operate in extreme pressure regions with nearly three-times the load which can be handled with a conventional petroleum gear oil"
It can be gear teeth contact area or surface of thrust washer working against side of the first gear
Though comparing it to "conventional petroleum gear oil" is not fair , they should compare synthetic vs. synthetic.
Vlad - the loads are far different...the pamphlet talks about gear mesh loads which put a pretty severe shear on any lubricant. Thrust loads are a completely different issue and do not require the high pressure additives present in the Heavy ShockProof.
It's fine that you use this oil for a very specific purpose (I would still use MT-90) and as long as you understand the long term effects, but recommending it for use in a tranny to your average guy on SM is not good. That's kinda the whole point in this debate
FYI - Red Line is in a class by itself even when talking about synthetics...it is an ester based oil. IMO the finest basestock available.
