I decided to try having some of the stock cast aluminum parts anodized, plus I had the aluminum pipes I bought anodized red also.
GrimJack;1313043 said:I'm assuming that really looks red in person, instead of pink, and your camera simply needs some color adjustments!
I DO TOO!!!!NewGen;1313079 said:OOOO I wanna see it installed!
The reason why it isn't glossy is because you can't get a glossy finish on castings, and the reason why the tubes aren't glossy is because I bead blasted them first to give them a matte, velvet like appearance.85celicasupra;1313094 said:I woulda went for more of a glossy anno job...
A red anno like on my invert mini would be sweet
it's the camera... I suck at taking good pics also.Clip;1313096 said:the ano shouldn't be affected by heat. it's pretty tough stuff, i love it i'm not sure if the lower intake is dirty, the anodizing is thin, or the camera is splotchy but the ic pipes and the compressor housing look awesome.
85celicasupra;1313107 said:if you dont mind me asking, what did it cost to get all that stuff annoed??
4U2QUIK;1313348 said:I DO TOO!!!!
it depends on the casting also. I've polished the living crap out of some other toyota parts and they came out matte anyway. I think it has to do with the specific formulation that they use for their castings.jmanbball;1313354 said:You can, but you have to polish the hell out of them first. I like the matte finish better though.
Clip;1313358 said:we did some anodizing at home for a school science project. only thing that was hard to source was concentrated nitric acid to clean the parts before we dipped them in sulfuric with a batttery charger running current.
4U2QUIK;1313438 said:there's ways to get around the nitric acid bath.
