Recommended tyre pressure
May 18, 2007
704
Aarhus
Someone told me that the wider the tyres the higher is the recommended tyre pressure.
If so how much does the tyre pressure increase with rim/tyre size?
On a mkIII running 18 x 8.5 and 18 x 9.5 with 235 front and 275 in rear what would be the recommended tyre pressure?
He recommended a pressure of 40 psi (aka 2.8 bar).
It seems a bit high?
Since the tires are different size front and rear should the pressure be different too?
Any input?
AJ'S 88NA
2,419
Florida
Any input?
I always run close to the max pressure on the tire. I have found that you need the max pressure to keep the sidewalls from being sloppy. Also if you don't the center of the tire will wear quicker.
Same but last time I mentioned it the resident genius's tried to tell me I was wrong.... blahblahblahbullshitbullshit.....
The general consensus seemed to be the 20 year old placard knew better than the manufacturer of the 35 series modern rubber I use...
AJ'S 88NA
2,419
Florida
OneJSupra;1347590 said:
I have 255/275 front and rear and I set mine 36/34 psi.
Have you noticed the middle of the tires wearing? Low profile tires need the extra pressure to keep the sidewalls tight.
IJ, yeah I've been told the same BS, run at a lower pressure, feels loose, and wears them like the old tires did with too much pressure.
May 18, 2007
704
Aarhus
Ok, I'm not sure if I get the sarcasm (if it is there), but my tires says max pressure is 51 PSI.
So should I run 45 psi? 40psi?
