Rebuilt short block?
Nick56289
Well after careful time and consideration (and saving up a crapload of cash) I have decided that im going to buy a rebuilt shortblock to put a MHG and my head on. I dont have the time or the space to do a rebuild and I dont want a longclock. I just need to know where is a good place to buy one. Does anyone know or have any reccomendations? Im in the bay area california if that matters.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Nick56289 said:
No one knows where you can get a rebuilt shortblock from?
How much you want to spend on one, I will sell you a fresh rebuild but I would have to know what you all want done to it.
lagged
1991 1JZ
new rochelle
i have one rebuilt with EVERYTHING new. new .20 over pistons, new crank, new rods, all new clevite bearings, new water pump, new oil pump, new ARP rod bolts, EVERYTHING new.
depending on where you are located, i will deliver the shortblock to you personally for NO CHARGE.
rakkasan
Currahee!!
Fort Campbell, KY
^^^^great deal, too.
lagged
1991 1JZ
new rochelle
i just read that you were in the bay area, so i couldnt deliver it to you but i will work with you as much as i can on shipping. PM me for more information.
Briskie
11
Londonderry, NH
I saw your post. I have a supra I just purchased the top half was rebuilt unfortunately I have a piston or rod knock now.
I need a short block rebuild. Approximately what would this cost to have done?
Thanks for any help you can provide.
Tony B
Briskie
11
Londonderry, NH
I saw this post. I see you (the rebuilder) are located in New rochelle.
Can you give me an approximate price for a rebuilt shortblock, Also would you do the work if I get the car to your shop?
Thanks for any help.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Tony B
Well there is shipping to and from, plus I would need to know what you would all want done. Stock type rebuild or performance type rebuild? Stock rebuilds can run up to 2k in some cases depending on what is all wrong with your short block. Performance block cost about the same in labor, but you have the increased cost of the higher end parts. Price is very dependent on your choices.
