Rebuilt motor, cranks over but not building oil pressure
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
You can get 1/8 BSPT male to 1/8 NPT female adapters, just do a search. You should just get a manual oil pressure gauge, such as from an auto parts store, they are cheap and more reliable than an electric dash mounted gauge. Once you know you have oil pressure you can figure out whats wrong with the stock gauge, if thats the problem, and fix it. I suggest you don't start it until you know for sure with a gauge that you have oil pressure, you will destroy your brand new engine if it turns out something is wrong.
suprarich
Guest
Nov 9, 2005
2,187
ohio
I also say you need to put a mechanical oil pressure gauge on that motor to check for pressure prior to allowing it to fire.
mk3-4-me
669
Milwaukee, WI
I just got an oil pressure gauge from autozone... I had to tap is to a m10x1.25 I think... It's not that bad.. I would deff get a mechanical oil pressure gauge anyways, it's deff allot better..
