part of a larger build, but refreshing the front sub frame first.
It came out of the car with no problems, already had the engine out.
replaced the wheel bearings, subframe bushings and control arm bushings.
Putting it back together now and could use some assistance from those that have installed RonnieK bushings
I have the bushing installed in the subframe with the sleeves. I have the sleeves flush with the bottom of the bushing. The top of the sleeve sticks up at least half an inch, and when I put the top cushion on the sleeve, the cushion floats on the top of the sleeve. I dont think this is correct, as it would let the subframe float up and down on the sleeve?!?
