Thanks!
Ok, rear pads are barely worn (there's a smidgen more on them than my new semi-metallic pads), and from the looks of it, my parking brake has plenty of pad left, but the cylinder wall is a very slightly bit pitted where moisture pooled up. Not nearly as bad as the front was, but given the amount of rust in my fluid I'm going to flush the whole thing; then get new calipers, and a master cylinder to have better peace of mind.
Kinda stinks since I have it mostly torn apart and I have the seals and grease to rebuild the calipers, but I suppose I can save them for the next brake job.
Do I need the two anti-squeal shims for each pad, I seem to be missing some...
Here's the diagram so you can see them:
Last thing, I have a ton of named manufacturers to choose from, any recommendations on which to go with, especially for the master?
Wagner, Beck-Arnley, Centric, Raybestos, Nastra, Cardone... all for just calipers.
Beck/Arnley, Wagner, Bendix, Cardone, Dorman, all for the MS..
