Okay, so the driver's side rear wheel sticks out slightly more than the opposite side. causing some slight rubbing issues.
Anyways, seems that other may have the same type of condition... http://supraforums.com/forum/showthread.php?t=551627
Also seems like it'd be easy enough to loosen the SF bolts and slightly slide, like it says in the able link/thread.
However, I don't plan to replace the bushings yet and want to make sure I do this right (without removing every other suspension component).
Anyone have a pic which points out which are the subframe to chassis bolts and/or a write up that already has tips/tricks, and gotchas? I did not see any when searching the poly subframe bushings threads.
Thanks,
Elvis
Thanks,
Elvis
