Rear Right Side Serious Virbation after 60mph
SupraMario
I think it was the google
The Farm
IJ.;1457116 said:
90119-12100??
If that goes up from the bottom into the tabs on the LSD then yes that's it!!!
If this doesn't fix it, then I have another drive shaft. I'll try it.
SupraMario
The Farm
IJ.;1457121 said:
It goes in from the back.
Are we talking at the back of the Diff or the front?
It goes in from the bottom, srry the reply took so long I was working on someones PC. But it goes from the bottom of the Diff into the subframe.
SupraMario
The Farm
IJ.;1457164 said:
90119-14017?
You still need to check the Uni joint phasing as well doesn't matter if it only has 80k miles it's still 20 years old.
Well considering that is the only one that goes up into the subframe then that has to be it. I know two go in from the rear of the diff. and two go into the tabs on the diff. It was one of the ones that go up into the tabs on the diff, that picture had me confused.
SupraMario
The Farm
IJ.;1457164 said:
90119-14017?
True, I will, just going to fix this first, then see if I have some how twisted the driveshaft.
As I said earlier the missing bolt is a symptom NOT the cause..... :nono:
There is a logical progression to diagnosing a problem,(ie: a>b>c>d) you seem intent on jumping all over the place, it's very frustrating.
SupraMario
The Farm
I understand, I'm not trying to jump all over the place, I was just trying to figure out the bolt, so while I'm under there today I can replace it. Then tomorrow put my other drive shaft in the car and check the uni-joint alignment for the one that is currently on the car.
SupraMario
The Farm
Welp, driving it back at 30mph, it has gotten worse. I now hear the carrier bearing flopping around like a dead fish on a dock....FUCK! Welp Gonna just put my other DS in it tomorrow.
SupraMario
The Farm
nick88;1457296 said:
Had the same problem, its the driveshaft.
Yea...Damn thing couldn't handle the BPU 2jz POWWAAAA
Welp, Shaftmasters is getting a call...I'm gonna drop some moneyz on it and get it fixed right, but gonna limp around on this other shaft for a while.
SupraMario
The Farm
Fixed it this morning. While I was under the car about to put the new shaft in there I noticed that three of the bolts connecting the driveshaft together in the center where just hand tight! WTF! I didn't touch these when I installed the DS in the car. Well I'm glad its fixed now.
SupraMario
The Farm
grimreaper;1457879 said:
I had three that were finger tight and one missing last month. SCARYYY.
Yep! The ones in the center are put on at the factory I never touched them and James got the DS straight from a car that had been wrecked but was pretty much stock and untouched. So I was shocked.
I say everyone should check these, I'm gonna loctite this fkers on thursday when I'm home in the garage.
