Rear Main seal question
BJ91T
810
Baton Rouge LA
Also Make sure your PCV/catch can setup is not causing to much pressure blowing the seals out. Thats what the issue was with mine Im sure IJ remembers my thread on this lol.
BJ
Cya
628
Columbia, S.C>
IJ.;1029509 said:
Never used #1 but #5 is closeish to #4 in properties ;)
Dunno if FIPG would work as I've never tried it.
(I tend to stick with what I know)
I cheacked all my local stores and their website and no number 4 or 5. :cry: Are you pulling my leg?
castrol supra
Semper Fidelis
May 8, 2008
95
The Back 9.
Chances are it is something different here than it is there.
Try cross referancing part #'s and see what hits.
Ij, is on the other side of the globe man.
It may even be called something different and packaged differently as well.
I was speaking to someone in the UK about loctite and there's is all gray tubed and part #'s. Nothing like here in the states.
Justin
Speakers?
Spokane, Wa
Cya;1030550 said:
good point. Part numbers, different names. sorry about that.
Find it?
I just pulled the front part of my engine apart and found my leak. Turns out it was my front main seal. I'm going to re-do all and I want to make sure I do it right this time.
