Rear main seal help
MKIIISupraGuy
639
Lousy-ana
Having trouble getting the darn thing out, I have all the bolts removed. Some1 help me out lol.
boostcraver
372
Louisville, KY
hvyman;1673474 said:
Oil pan might be holding it on. Pry it.
Might be a dumb question, but, you DID remove the oil pan bolts in the bottom of it as well, right? I know you said all the bolts were out, but it might have been something that was overlooked and I can't see past the lip on the pan in the pic you posted.
MKIIISupraGuy
639
Lousy-ana
Yea I did, and I finally got it out. Now I need to know how to get the crankshaft bolts to break loose. They are tighter than what a cheater bar can handle. I know.. I need a service manual. I been looking for 14 months, ever since I got the car. Pic for clarification of what I'm talking about:
Dont need to remove those for rear main.
So is the engine in the car?
What are you doing?
Those are only torqued to like 75ft lbs. A breaker bar would take them off easy unless the engine is spinning still on the hoist.
MKIIISupraGuy
639
Lousy-ana
Its on a engine stand, and I'm trying to replace the crankshaft. When I bought the car it had a OBX underdrive on it. I put a OEM crank pulley on it, but the damage was already done. Two weeks ago the oem pulley developed a slight wobble. Back when I put the OEM pulley on, I noticed the keyway in the crankshaft was messed up from the underdrive pulley. I found the original keyway today when I pulled the timing belt cover off. Right now I am jut hoping the motor will be ok. Thanks for TSRM link, scanning it now for info...
D.J.T.
877
Arkansas, United States
How does a Breaker bar fail on those bolts? Im assuming you need a BIGGER one.
& if you ever need the keys that go on the crank, go to Toyota. Tell them you need the "Woodruff keys" that go on a 6M/7M crank. whatever you have.
