when i'm at about 3k rpm i can really here a hum in the back only when i'm on the throttle. what is causing this? is it a bearing in the axle? any help is greatly appreciated thanks.
well it leaks in two spots and i filled it with 90 weight gear oil so its not empty but so far its looking like the bearing by the driveshaft... at least from what i've been told. no when i back off the throttle or have it in neutral it doesn't hum.
