Rear Diff Fluid Recommendation
mjmendoza
95
San Jose
i am just wondering what the best gear fluid would be to put in the rear diff. from what i was told 80w-90 is the right fluid but i want to know what you guys put in your rear diffs.
AJ'S 88NA
2,419
Florida
Check out the Oil and Lube section on the main page, all you need to know about it in there, brought to you by none other than Jdub :)
Island_Yota
264
Vancouver Island
Im wondering this aswell, checked the Lubrication/Oil forum and didn't find much info. My LSD is starting to make the chatter sound, want to change it asap along with the transmission fluid, from what ive read Redline Mt90 is the way to go for the W58 but im still not decided for the rear end.. Ive heard Ford 80w-90 with a few Oz's of Ford LSD additive works good for higher mileage cars?
The Ford LSD oil is a 75W-90 and you will need the LSD additive. On high mileage differentials, I think it's a better choice.
It's Ford friction modifier...it allows an LSD to "slip" for proper operation. I would start with one oz.
Red Line 75W-90 is another good choice and it has the friction modifier already in it. On a high mileage LSD, you may get clatter with Red Line.
grimreaper
2,180
Dallas
what would you consider "high" mileage? low mileage on these now a days is what, 90,000 miles?
If you put Red Line in it and it clatters, it's high mileage :D
Seriously though, a better phrase is "well worn" and that is a judgement call. If it's seen abuse (autocross, burn outs, etc) or if the oil was never changed, it's probably worn. Under normal city/highway driving and periodic oil changes, I would consider the 150K point as "high mileage".
topdog849;1711645 said:
be sure not to use any fluid with friction modifiers.
You bumped a 2 1/2 yr old thread to say BS like that? A LSD requires friction modifiers - a std differential does not, but friction modifiers will not hurt it or make a difference. A manual tranny is a different story.
