My 89T was throwing a 21 code so I salvaged an o2 sensor off a parts car 90t. (a 3 wire to be specific) As stated in the TSRM, I checked the resistance and it was within the specs 3-3.6 ohms stating it was still good. Question: If i splice and extend the wires then solder and heat shrink tube them will it still be okay. I need to extend them because my 02 bung is further down the 3" elbow than a stock. I have heard that once you cut the wires, the insulating jacket of the wires will be ruined and give you false readings thus giving you CEL also. Any info and suggestions of how to go about this problem will be appreciated. Also if you guys can recommend a 02 sensor (3 wire) brand, type, make, model....in case I cant extend them.
