Hi, I have a 1996 Toyota Corolla 1.6 liter Single over head cam automatic. I decided to install a Protach Tachometer in the car for safety reasons for when I travel through the grapevine. We hooked up the green wire to the disbutor, The red wire is hooked up to the radio acessory fuse and we grounded the Tach wire with the aftermarket alarm wire and everything worked. However the Illumination wire for the tach was not hooked up so, we looked at the kick panel fuses and checked to see if you could install it with the cluster fuse. We first attached it to the wrong fuse by accident which was the ignition fuse and the tach light stood on. we attached it to another fuse which did absolutely nothing. Then we finally got the right fuse and it worked when I turned the lights on. When it came to start up the car it cranks but it does not start we checked all fuses in the kick panel and engine bay. We are not sure about the relays. Any ideas on what happened?
If any has any ideas to get me on the right track I would much appreciate it I need the car by Tuesday for work my Supra is under constuction and now my beater took a dive..... Please no comments saying that I am retarded or something because I didn't do the work.... I am just relaying the message.
Thanks guys!
Thanks guys!
