Reading knock on SAFC II? (Post your values.)
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i start to record my nock when my car was runing last once car was warmed
teh avage nock you really want is 150 or under i was sure to my self after 150 ish the ecu whould pull timing alot
this was done useing timing gun on a dyno
what whould be neat si to have dagree wheel installed on you damper and shoot it with a timing gun
and brent he best way to record your nock is with camra and a buddie holding ti or monte of some sort
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I think a good way to test the consistancy of the numbers would be to re-set the ECU after the car has been fully warmed up. Take the car for a WOT pull while recording the values. Re-set the ECU and repeat. (under same conditions of course, same strech of road, same temperature, same boost ect.).
I would look for consitancy in the values because they should be virtually the same. If there are no consistancys.. I'd try sheilding the wire. If you repeat and there are still no consistancys, I think we have our answer...
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yes but camra chould take 2 hours of testing get the idea more data loggin = more data
plus you can watch 2 vids at the same time to see if they coppy each other
MK3Brent said:
Why?
The AFC has up to a full minute to play back your readings. :)
