It runs great now but now I have another problem. The fuel damper leaks out of the top. Replaced the washers still leaks. I put a good damper on and still leaks out of the top, not by the threads but on top like where the lip is under the plastic cap. I read somewhere that you could replace it with a banjo bolt. I did that and it no longer leaks. Now the problem is I hit fuel cut after 3k.... not every time but more then not. Was this a smart fix? I think the problem might be because im running a walbro fp, its a 283lph pump. Any advice? ??
