Disced said:
You all seem to be under the impression the stock pump can't flow?
Just to put my .02 cents in.
I run RC550's/Lex for approx. 1 1/2 years with no problems, not even problems @ idle with between 16-18 psi on the stock fuel pump and stock afpr.
When I dynoed @ 278HP and 337 TQ @ 16 lbs my A/F ratio was less than 10:1
You tell me if the stock pump can handle it?
Ofcouse it is possible.
You can also use your old 440cc injectors with the lex afm. Even that is very well possible.
The real question here is do you really want to rely on older stuff in something as important as your fuel delivery?
It's the same as the 440 injector example above, would you want to be pushing a 16 year old fuel pump which never had to deliver more than about 70% of it's duty cycle to its maximum?
You can guess what happens when it fails. And it's more probable that the old pump will fail than the new one.
At least, this is how I see it.
