RC 550 injectors
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
are the RC 550 injectors a direct replacement for the USDM 550's? and does anyone have any thoughts on their quality?
i have the opportunity to get a pretty good deal on a set right now, and i was just wondering if i should go for it.
thanks.
jdub
Feb 10, 2006
10,730
Valley of the Sun
If you're referring to RC Engineering 550 low impedance (Lucas) injectors...they are a direct fit on a 7M, but you have to swap out the harness clips. RC sells quality injectors...I use them. Always have any injectors tested for flow before installation...if used, I'd have them cleaned too.
Not too sure what you mean by USDM 550 injectors :dunno:
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
7M's are top feed so they are a direct fit, JZ engines are side feed so you will need a fuel rail and if they are low imp a resistor pack.
