rattle in the rear.
applesauce
Banned Scammer
Aug 24, 2006
705
Virginia
Im almost sure its the Strut rod bar bushing that needs to be replaced. The wheel almost feels like it comes out a little from under me and then pops back in. I jacked it up and moved the wheel side to side up and down. Only play i got was that bar/bushing. I know suprasport sells LIPP bars w/ poly bushings but them shits ar like $330... any ideas on how much stock bushings cost? or would it be easier to just grab some used ones and spend the money next time.
Wiisass
If you're getting that much play, I hope you fixed that problem by now.
But it all depends on what you want to spend. There are aftermarket arms that you can buy, you can get new bushings for the arm, you can pick up a used arm with bushings that aren't blown. It depends on how much you want to spend and what you want to do.
