Initially it would die for no reason once every month or so. Now it's every 10 min. First the check engine check light would turn on then the engine dies. It doesn't matter if it's in idle or neutral. The engine code is 14 and ECT code is 61 (which is probably unrelated). Voltage is good, new alternator, new battery, dashpot, CPS seems in one piece, grounds are tight, boosts fine.
Any ideas?
Any ideas?
