yea, sounds like cam seals, and you don't have to take the valve covers off to replace them.
Also, to remove the cam gears, I didn't use an sst, I just had someone hold a screwdriver inside one of the cam sprocket spokes (there are two bolts behind each cam sprocket) and use the tension between the spoke and the bolt, and it worked fine... Just a thought...
