radiator hoses.
di_rosa
never ending project ...
Apr 2, 2005
215
toronto
it looks like the upper will fit if you chop a few inches off each end, but i don't think the lower will. the mkiv rad is longer than ours, so it might just need trimming as well, but i'm not sure.
AZN MK3
341
Now in the U.S.
mischief7m;948838 said:
does anyone know if you can use 2jz radiator hoses on a 1jz?
thanks
to make things easier just get the rad hoses from a 7mgte both upper and lower fits... the 2jz rad hose will fit but only the top one fits....
mini_me1209
MZ21 1jz Single Turbo
May 27, 2007
82
Lethbridge
Just installed a 2jz lower rad hose on my 1j. You need to cut about 4-5 inches of the end that connects to the rad. Other than that, it fits fine.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
top was about the same size as 7m's and i bought a 2jz lower rad hose and cut 1'' off for it to fit
