Radiator Fan Shroud dilema
edi
198
www.pxracing.com
so, my radiator fan shroud broke on me whille i was driving and i had to remove it. the dealer wants almost $200 for a new one, i cant find any good ones at the local junk yards and i cant find any in any for sale sections. is it safe to drive around with out the fan shroud? any suggestions?
thanks in advance.
born2drv
1,199
Burbank, CA
find a local toyota dealer that will give you a 20% shop discount.... tell them you have a repair shop, 1/2 the time they won't even ask for proof. if they do, go register a d/b/a for like $10 or whatever at your local city hall. it's well worth the time and effort to set up this type of account. i've probably saved $500 or more from my 20% toyota discount.
i bought a new fan blade and shroud from the dealer.... don't cheap out. i drove without it for 1 day and it did slightly overheat in slow moving traffic, so i stopped driving it and ordered right away. i considered getting dual fans and ditching the fan blade/clutch, but i read a lot of posts with people who were unhappy with their electric fan setups.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
ive been driving around for the past few months on my rebuild in as hot as 90-95degree weather and the temp nedle never moved past half. ull be fine
edi
198
www.pxracing.com
but it seems as though my fan is engaged a lot more than with the shroud on. and i can feel a drag in the motor when it is engaged, its kinda anoying. i can see why people would want to go with the electric fan set up.
tissimo
Stock is boring :(
Melbourne, FL
I drove around in FL head w/ ac on without a shroud no problems... I finally put on on today and hopfully my ac will work better at stop lights, lol
FredMk3
mk3 for life!
Sept-Iles/Quebec
Get a new fan shroud from Champion like isnms said, that's your best bet. For 100$ shipped it's a pretty good deal and no hasle. I wouldn't swap to electric fans, heard bad things about them. IMO The stock fan is pretty damn good, flowing alot of air. You hear the fan more cause you're probably running a bit hotter without the shroud causing the fan to run faster. Get a new one and your set. ;)
born2drv
1,199
Burbank, CA
IJ. said:
Chunks: "Half" on our gauges is DAMN hot!
LOL I was thinking the same thing!!
Normally when everything is cooling well your car should be around the 35-45% range.... just under the half way mark. 50+% is not good at all. When I drove without the shroud it touched around 55% or so and I stopped driving it.
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
for reference... when my stock temp gauge was at ~40% my water temps were 220+ degrees, (broken thermostat)
so I dont even want to know how high my temps would be if it were at 50%
granted that guage is incredibly inaccurate so what it was for me might not be the same for you... but get a shroud on there quick, it made a HUGE difference for me.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
I've NEVER had a fan shroud on my Supra since I've owned it (over a year).
My temperature gauge, from the very bottom line (C), is about 30% of the way up...Yeah, it stays plenty cool for me. :D
born2drv
1,199
Burbank, CA
with a stock radiator? that's very good.
i'm going to be replacing my rad with the PWR unit, hopefully that will lower my temps.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
well after i put the shroud on its staying the same half just under half on the gauge. factory toyota thermostat on a fresh rebuild and a freshly cleaned and checked radiator. everything i put in my car waas either brand new or the stuff i was running that i had cleaned and checked.
its been running for the past 3-4 months with no problems (knock on wood)
next time i drive it ill put my temp probe on the top of the radiator, should be a good enough guess on what the water temp coming out of the engine is.
