i have an 88' 7m-t 5spd and have just have been noticing that my 1st and 3rd gears grind real bad. the day before it wasnt grinding in gear at all. it goes into gear just when it is it grinds. 1st is a slower grind and 3rd is faster. when my clutch is out it makes a bad bearing noise which i believe is the throwout bearing but im not 2 sure. so with that said could it possibly be the clutch system or is the tranny out?
o yea i forgot to mention that its not all the time. some times it will be just fine. no real pattern at all
