ill make sure to get it done but i cant upload the video from my phone so itll be later in the evening after i get home, but expext it to be posted her before the night ends.
Smashey;1881195 said:Here is a video I took its crappy cause I had nobody to hold the light
https://www.youtube.com/watch?v=wYZ4LyCBwuA&feature=youtube_gdata_player
I also took pictures that I can't upload till later, but they show everything clearly
hope I could help.
Matt.
Dan_Gyoba;1881288 said:That doesn't look like it's working either. I'm not seeing any movement at all in the clutch pressure plate.
Poodles;1881309 said:It's fine... you're pushing the wrong way and it's obviously your hydraulic system.
Smashey;1881429 said:Correct Dan cause it wasn't in the car and i wouldn't expect my hand to pull the clutch in as effectively as a hydraulic system. that being said i agree with poodles because mine looks the same and when i hook up the slave tomorrow it better work! actually later today...
steve_mk3;1881532 said:This may help in determining if everything is correctly put together
http://www.mkiiisupra.net/bbs/showthread.php?36924-Guide-Clutch-assembly-7MGTE
Dan_Gyoba;1881519 said:Expecting to move the clutch pressure plate with a screwdriver is like expecting to lift your car with a jackhandle.
jaze;1881442 said:keep me updated if you can, i actually tried to depress the lever with a screwdriver and it felt like it was at its maximum travel like it couldnt go anymore. Please keep me updated in your process, it would help me out infinitely!
Poodles;1881550 said:Also, as this has to be said, as people seem to skip it.
ANYTIME you change any components in the clutch system, you MUST readjust the clutch pedal freeplay.
Too little freeplay and you're basically riding the clutch causing slippage, glazing, and premature wear. Too much and the clutch isn't going to disengage properly and you're likely to damage or wear the transmission.[/IMG]
