R154 Issue
Mk3Manny
4
Im writing this at 2 am.
recently my transmission gave out. Clutch pedal lost pressure and won't go into gear (obviously). I jacked it up and took the inspection plate off where I was able to see that everything (bearings and such) just hanging there. does anyone know what could've caused this? it gave me no issue but it did sit for a while since the bushings were shot.
Im short on time and have been busy with everything so I haven't been able to take it apart. on that same note, what parts will most likely need to be replaced? id rather buy it all so that I can spend a day fixing it than having to wait on parts once I take it apart. thank you for your time and help
-Manny
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Clutch, flywheel, pilot bearing, throw out bearing, fork pivot and retainer, master and slave cylinder. You're not gonna drop the transmission for nothing. Change the transmission fluid as well. Also plan on more than a day.
