I was just looking at a photo of the hub and noticed im missing the washer number 31264a. How much of an effect would that have to my issue?
hahahaha .. worn rubber lolIBoughtASupra;1822860 said:A slave does not have to be leaking for it to be bad....you could be loosing pressure internally from a worn rubber.
wht95scort;1822866 said:I was just looking at a photo of the hub and noticed im missing the washer number 31264a. How much of an effect would that have to my issue?
when i bleed my slave i have to remove it from the housing and bleed it bye hand.. i pumped and used a power bleeder for over a hour with shit ass results, take the slave out and pump it and pull it the full length of the rod.. lol and no this is not a porno story lol evn though it sounds like one.wht95scort;1815669 said:Well replacing the clutch master did not solve my issue. Still doing the same thing. If i pump the clutch pedal a few times i can get it into gear. I will try replacing the slave and try again. Also how heavy should the pedal feel? As it is now it seems pretty light and it has a performance clutch.
