My R-154 leaks from the back area, around the area where the drive shaft meets the trans. I just replaced the drive shaft/rear output shaft seal on the trans and it still leaks.
My question is, where else could the leak be coming from? I looked everything over when I took the drive shaft off and I did see a little fluid on the part where the shifter area is at the top of the trans. Can the trans fluid make it up that far if I have the correct amount of fluid in the trans?
Some history on the trans : I did rebuild the trans last summer by myself. I also checked the fluid level and made sure it wasn't too full. I did notice about 1/2 a quart came out the weep hole when I checked the level. But now its leveled off.
Any help would be great. Thanks
