Quick Question?
Turbo Habanero
4,229
Tucson,AZ
So i am just getting around to pulling the motor from my 87 Turbo and putting it in my 89 Turbo......About time i Know.
So here's my question the 89 is a Auto and my 87 is a Manual i am going to switch transmissions also so i here all i have to do is Ground the Neutral Safety Switch?
My Starter is currently Wired to a push button Start in the 87 so all you need to do is put the key in and turn it in the ON position.
So my question is do i absolutely have to Bypass this wire?
Reason for asking is i did a search be for posting and read that if you have your starter wired to a push button you don't have to do this..Also said something about it being able to start in gear,I don't know anyone that would care to explain more it would be very helpful and appreciated.
Also any other heads up or advice would be helpful.
Thanks in Advance
-Jordan
Turbo Habanero
4,229
Tucson,AZ
suprahero;1462220 said:
I didn't wire mine in and it's got a push button start also.
So all i need to do is slide the B**CH in and hook everything up then im good?
Lol Can't possibly be that easy.....
It's been so long since I did my swap, I can't remember. I do know that everything I needed to know, I found on here. Hopefully you can find it. Good luck. The hardes part of the swap for me was installing the pedals. I'm not as limber as I once was and I barely fit in the floorboard. I ended up removing my drivers seat so I could get under the dash easier.
Turbo Habanero
4,229
Tucson,AZ
OK Thankyou very much
-Jordan
Turbo Habanero
4,229
Tucson,AZ
So any Last minute info anyone could share about anything thats has to do with pulling a motor and transmission from a 87 and putting it in a 89 also auto to 5-speed i will be starting this in the AM so anything helps please feel free to leave any info or advice..
Thanks
-Jordan
