Quick question about removing tranny.
Warpath
Help me Jeebus!!
Oct 28, 2008
135
St.Louis
Failure14;1519114 said:
Ok i got the clutch fork out! yayy.
I feel like an idiot though...
Anyways do i wanna start prying my transmission
off the block now? or is there something else i have to do?
well don't. We all start somewhere. You should be able to slide it out now.
-Jim
whitemike
1,164
Winter Park, Florida, United States
hvyman;1518834 said:
There is a "c" clip holding the pin in on the clutch fork. Remove the clip and push the pin out and it will slide right out.
edit: Or you can remove the pressure plate.
The pin doesnt need to be removed for the fork to come out..
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
I don't think you should have to pry it, make sure you didn't miss anything before you start prying shit.
Failure14
276
Ohio
Jeesh...
Ok i got the clutch fork completely out, all the surrounding bolts on the bellhousing but the tranny
just isn't coming, i've tried prying it a little bit but nothing budges...
Its still on my engine hoist and ive tried jacking it up to where the tranny has a little pressure on it and still nothing.
I went by the TSRM on removing the bolts so idk?
Is there something else im missing?
Ive got the starter off, clutch fork, and surrounding bolts ont he bellhousing.
Failure14
276
Ohio
whitemike;1519137 said:
Checklist:
-Starter
-Slave cyl
-Pressure plate bolts
-Clutch fork
-Bellhousing bolts
---------- Post added at 12:01 AM ---------- Previous post was at 12:00 AM ----------
Also, if you do pry it pry it EVENLY.
Mmmm pressure plate bolts, thats what i didnt do.
Well im gonna go try that lol.
If you unbolt the pressure plate the trans can come out without the fork being removed. just wiggle the trans with someone helping you and it should come off no prob.
